Displays virtual link(s) information.
| router_identifier | Specifies a router identifier, a four-byte, dotted decimal number. |
| area_identifier | Specifies an OSPFv3 area, a four-byte, dotted decimal number. |
N/A.
Router-identifier—Router ID for the other end of the link.
Area-identifier—Transit area used for connecting the two end-points. The transit area cannot have an area identifier of 0.0.0.0 and cannot be a stub or NSSA area.
The following command displays information about the virtual link to a particular router:
# show ospfv3 virtual-link Neighbor Router ID : 0.0.0.3 Transit Area ID : 0.0.0.1 Hello Interval : 10s Router Dead Interval: 40s Retransmit Interval : 5s Transit Delay : 1s Instance ID : 0 Via Interface : intf2 State : P2P Num of State Changes: 1 Hello Due in : 2 Number of Events : 2 Hellos Rxed : 149 Hellos Txed : 148 DB Description Rxed : 2 DB Description Txed : 2 LSA Request Rxed : 1 LSA Request Txed : 1 LSA Update Rxed : 2 LSA Update Txed : 2 LSA Ack Rxed : 2 LSA Ack Txed : 1 In Discards : 0 Local Address : 2001:20::1 Remote Address : 2001:20::2 Restart Helper : None Restart Helper Strict LSA Checking: Enabled Authentication : IPsec ESP SPI : 500 Algorithm : HMAC-SHA-512 Encrypted Key String: #$bC0GrQHhqjeDABqYwnlfdihIsOhV9g== Virtual Neighbor: RtrId: 0.0.0.3 IpAddr: 2001:20::2 Type: Auto State: FULL DR: 0.0.0.0 BDR: 0.0.0.0 Dead Time: 38 Options: 0x13 (-|R|-|-|E|V6)
The following command displays information about the OSPFv3 virtual link authentication with default (none) configuration (line 19):
# show ospfv3 virtual-link Neighbor Router ID : 0.0.0.3 Transit Area ID : 0.0.0.1 Hello Interval : 10s Router Dead Interval: 40s Retransmit Interval : 5s Transit Delay : 1s Instance ID : 0 Via Interface : intf2 State : P2P Num of State Changes: 1 Hello Due in : 2 Number of Events : 2 Hellos Rxed : 149 Hellos Txed : 148 DB Description Rxed : 2 DB Description Txed : 2 LSA Request Rxed : 1 LSA Request Txed : 1 LSA Update Rxed : 2 LSA Update Txed : 2 LSA Ack Rxed : 2 LSA Ack Txed : 1 In Discards : 0 Local Address : 2001:20::1 Remote Address : 2001:20::2 Restart Helper : None Restart Helper Strict LSA Checking: Enabled Authentication : None Virtual Neighbor: RtrId: 0.0.0.3 IpAddr: 2001:20::2 Type: Auto State: FULL DR: 0.0.0.0 BDR: 0.0.0.0 Dead Time: 38 Options: 0x13 (-|R|-|-|E|V6)
IPsec Authentication information was added in ExtremeXOS 31.2.
Authentication Trailer information was added in ExtremeXOS 31.3.
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
